just two questions
just two questions
OK at last, i finally have dsl Cheesy
so where do i go to find out all about P2P etc??
and 2 what tweaks should I use to ensure i have the FASTEST speed
cheer folks
Adamski Tongue
Ianwild
just two questions
HI,
We need to get all the tweaking information in the forum - The PlusNet forum over at http://www.adslguide.org.uk is currently the authority on such things. I'm sure we can change that with a bit of effort!
If I get time tomorrow I will collate everything from there and make a sticky post here.
P2P is a big area - I will leave someone else to answer that one, suffice it to say searching Google is your friend in this area!
Regards,
Re: just two questions
cheer folks
Adamski Tongue
As Ian said p2p is a big area and there are several programs you can download to use this.
I currently have winMX working and its easy to set up and does all that I need.
If you do a google search for it you should find a few sites to down load it from.
just two questions
A couple I know of are:
kazaa
limewire
emule
just two questions
If you realy want to goto the kazaa area of the woods, download kazaalite.
It is the non-spyware version.
In adition, a good virus scanner, and a spyware removal tool like AdAware (lavasoft.de) will be both your best friends, and essential tools for keeping your computer, data and privacy safe.
