is this true!!
is this true!!
so if i read this correctly, PLUS.NET are going to increse my line from 2 Meg 256 up to 8 Meg 512 up (if avalible in my area) at NO extra cost to myself, and no increase in my mothly payment.
is this what you mean by a free upgrade if so i am impressed :shock:
i will watch this space later all
is this true!!
Its basically true, but the 8M is bit of a holly grail.
Chilly.
is this true!!
Yes it will depend on the ability of your line to support the higher speed but you will be able to get up to 2mB in April and the possibility of up to 8mB as BT update exchanges in the future.
There will be no cost for the upgrade and you will continue to pay the same fee for your connection so if you are on a 512k connection at the moment then you could possibly get 2mB for your £21.99.
What will be introduced along with this is a Fair Usage System and depending what you pay will determine your usage limits. 30gB per month for the £21.99
