is this good stats i cant seem to understand them
ADSL Link -----------Downstream ----Upstream
Connection Speed--- 8128 kbps -----448 kbps
Line Attenuation-----------35 db--------- 11 db
Noise Margin --------------3 db -----------24 db
should noise margin be higher than 3 db
vic_newey
I'm amazed you are connected at 3 db, needs to be 7 or more . preferably 10 upwards
Its likely your modem is not giving accurate stats
Alecto
On MaxDSL, doesn't the SNR settle at about 6?
That is what I recall reading a number of times around here somewhere.
But 3 can't be right.
not necesarrily, as long as you have margin to spare it will connect as fast as it can. Although given the small margin I would expect to see lots of errors. What will happen naturally is as the margin goes smaller, the modem will retrain and your sync speed should repeatedly alter accordingly until it finds a stable rate.
For instance, on my first day of max I connected at about 3000k (with a target SnR of 6dB set by BT). As the day progressed and noise levels rised, the SNR gradually went to zero where the modem retrained to find the next stable speed given the available SnR at the time.
it wont sync at less
it stays on that i turned it off for an hour
i have rebooted every day hoping to change the bras thingy
im still stuck on this 2 mb bit in profile
i got maxed on the 02 May 2006
which is 4 days ago think im going to have to wait till the 10 days and +2
Sad
the only good thing is i havent lost connection once yet and its not unstable like some of the members here
