is port 4662 blocked?
Even with ZoneAlarm shutdown, i dont seem to be able to use port 4662.
The XP firewall is also disabled.
Does anyone else have this problem?
cheers
chino
RE: is port 4662 blocked?
I am on the ADSL home account and i use that port for Emule so no it is not blocked on the ADSL home surf yes...
cUnDaLl
> cUnDaLl
Im on ADSL Home as well, not home surf, and i cannae get it to work with emule, says port 4662 is unreachable and gives me a lowid.
all Firewalls are off.
I can use allother p2p apps fine, a problem for technical support?
chino
i don't know what to say...
i have full access to e-mule well i think so but i can only download at 15kbps Sad
cUnDaLl
When you connect, in the connect window at the bottom of emule, can u double check for me please?
if u scroll the text up to where it says its connecting to the server and check that it doesnt say
"Cannot access port 4662, you are in LowID mode"
It does still connect, but yes, it will slow your downloads.
<snip/>
You need to have your modem/router forward port 4662 directly to your PC. Look for NAT in your modem docs.
See
http://www.edonkey2000.com/documentation/lowid.html
Graeme -
okeydokey, well i have a router,
the setup screens for it are here http://www.farina1.com/amx/
i added a new nat session called P00ter, then in the nat config added profile name P00ter, and ip , 10.0.0.6 which is the ip on my pc.
Thats right i guess?!
rebooted the router, and it still doesnt work....
do i have to add the ports on the Virtual Server page as well dya think? or any other ideas?
<snip/>
Seems so. Add TCP forwarding for 4662 to your machine. Then test it with the lowID link.
Graeme -
i did as mentioned and it still didnt work..
did a factory reset of router and now it seems to be working! STRANGE!
cheers anyhow
