irratic speeds
irratic speeds
Over the last few weeks I have noticed the speed of my 2mb connection grind to a halt on a regular basis. Whislt I understand over all usage on the network at the time can slow things down I do not expect the drops in speed I have recently experienced. See below for tonights varitaions from 498 all the way up to bt test results of 1725 when using the bt test domain/realm.
Surely the difference between results when using the bt realm against the plusnet realm suggest plusnet need another short term fix.
I'm starting to loose my patience, I can't rely on getting a decent speed on plusnet anymore.
can someone from plusnet please advise why these speed vary so much plusnet v's bt realm?
many thanks
A
Adsl Guide 22;22 18th April
Direction Actual Speed True Speed (estimated)
Downstream 712 Kbps (89.0 KB/sec) 768 Kbps (inc. overheads)
Upstream 170 Kbps (21.3 KB/sec) 183 Kbps (inc. overheads)
22:26
Your Connection
Downstream 761 Kbps (95.1 KB/sec) 821 Kbps (inc. overheads)
Upstream 168 Kbps (21.0 KB/sec) 181 Kbps (inc. overheads)
22:32
Your Connection
Downstream 1611 Kbps (201.4 KB/sec) 1739 Kbps (inc. overheads)
Upstream 237 Kbps (29.6 KB/sec) 255 Kbps (inc. overheads)
18-04-2006 22:33:17 1220.6
18-04-2006 22:25:20 882.7
18-04-2006 22:21:56 498.8
17-04-2006 21:13:36 1747.2
16-04-2006 11:09:33 1575.2
15-04-2006 13:30:30 1816.1
15-04-2006 13:27:07 1826.8
15-04-2006 00:07:02 1308.5
15-04-2006 00:06:10 1495.8
14-04-2006 23:51:02 929.1
14-04-2006 23:50:04 718
14-04-2006 23:46:50 1079.5
10-04-2006 21:44:48 1697.6
BT Speed test 22:30
The speed test has completed on test server speedtester1.nat.bt.com for user 0141****** and you have downloaded a 1.7Mb file at a speed of
1725 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
