installing drivers problems
Hello
Im a new user trying to install the drivers from disc supplied.
I keep getting the error message - Unable to install ikernel.exe
Any ideas?
Are these the drivers for the modem supplied by PN ?
It is usually helpful to state what equipent you are trying to install to give us a fighting chance of helping you with your problem.
Also OS version (i.e. Windows SP Sp2, Linux etc) would also help.
installing drivers
Yes I am using the modem supplied by PN.
AS soon as I try to run the install drivers program I get the error message: unable to install iKernel.exe.
I use Windows XP.
Would a system restore work?
Midville
You could try and download the driver(s) from their support page. See if that helps ?
Re: installing drivers
PlusNet supply a number of modems... Which one is it (name and model number) please?
Its a voyager 105
Its a voyager 105
Message deleted
davymurph,
Are you installing the drivers as an admin account or a normal user account. You need to be an admin to do it.
