installation problems
got my starter pack today started installing drivers from cd.(thinking it would be straight forward install) 3/4 way through process message please insert win98se disc. i did this but could not find drivers
everything has gone to a grinding halt - cant finish the install
any w98se users encountered similar problems installing?
Also have additional problem after rebooting inserted binatone disc stried starting installation process again error message coming up
"cant get registry value
Key = software\binatone\adsl
value= drivertype
any takers?
appreciated
ds
Boundey
what file was it looking for mate?
It could be embeded in one of the cab files ya see.
boundey,
have managed to extract some of the files from win98 disc but cant proceed with installation until have sorted out registry error message
thanks
dv
Download DUN 1.4 from Microsofts site, you have to search for it, it resolves the USB modem problems if you are having them.
I've not had a problem fortunately and run 98se.
Hope that helps
witty
Error message
DS777
The registry error message appears when you try to reinstall/uninstall the modem software after your PC crashes during the installation. To get rid of that problem you must get in touch with Binatone support and ask them to email a little uninstaller program (700K) that will fish out all the garbage that was left in the registry of your PC.
If the problem reoccurs, look at my post on a different thread.
GB
