i need to speak to customer service
can i get your contact number?
Customer Support: 0845 140 0200 | Broadband Faults Helpline: 0845 140 0080
Chilly
PS check the wait times here;
http://www.plus.net/supportpages.html?a=212
Fixes: 9
Save the queue... just use options 4 then 3 - Straight through to customer service (Note the other options try to tell you to go to the website and some options will disconnect you). 4 then 3 and you'll speak to a human.
Plusnet Staff
Plusnet Staff
Fixes: 159
But doing that it might not be the correct department, different options on the phone bring you to different sections in here. It is worthwhile taking the extra 30 seconds on the phone to choose the right options.
 Chris Parr
 Plusnet Staff
