http pages freeze (no data transfer)
has anyone else had this.
i am running 2gig athlon with windows 98se on 256ddr memmory with 40gig harddrive
my web pages freeze every 3-4 miniutes but i still get emails and file transfer program still transfering stuff....
but web pages seem to be broken...do i hae to reinstall windows again or is the a fault of plusnets...i havent had this problem untill just recently..1 month....
any have would do
chrisSad
RE: http pages freeze (no data transfer)
> any have would do
> chrisSad
Chris,
Have you tried deleting your temporary internet files. in IE it's under tools -> internet Options -> Temporary Inernet Files - Delete Files.
This may be getting a bit full ?
Also do you have lots of hard drive space spare ?
Bill
> > any have would do
> > chrisSad
> Chris,
> Bill
Chris,
I've had exactly the same problem but only since converting to Broadband. I updated just about everything, drivers, software, the lot. My system is a PIII, 450mhz, with 315mb RAM on Win98.
Eventually, on the recommendation of PlusNet via a problem ticket, I installed Netscape 7 and have not had the fault since. I have imported all my address books and mail etc and got rid of IE6 and OE6.
Give it a try, you don't have to remove IE if you don't want but your symptoms are identical to mine a few weeks ago.
MM
fonejacker
It is certainly an idea to ty a different browser, this will enable you to rule out the most likely cause of the problem - IE.
Personally I like Opera, from www.opera.com...
Regards,
Ian
> > > any have would do
> > > chrisSad
> > Chris,
> > Bill
> Chris,
> MM
CHEERS LADS
i got 160gig spare hardrive spare i just got myslef a new 120gig
it was nowt to do with the cache etc
more to do with IE
thanks
chrisSmiley
ps i still have the problem http page freeze
recieving data from other sources though ??
plusnet dont help much
Hi There,
I'm sorry if you feel we have been unhelpful. I hope that if you think about it you would agree that the Support team should concentrate on supporting our products, but your PC Manufacturer should support your PC and your software vendor should support your software.
The fact is that the above is not a problem with the connection we provide. We do have to draw the line about what we can support and we will always do our best (in fact more than many ISPs) to offer help above and beyond our call. The alternative to this would be that we increase our support remit. However this would mean increasing the size of the support team, to which the only outcome would be an increase in the subscriptions we charge customers or a removal of investment from another area of the business.
Sorry if I sound a bit defensive - We are here to help and we do our best but sometimes it can be hard for people on our side of the fence to accept that we have to support all of the problems which result from the corner cutting adopted by PC hardware and software manufacturers!
Regards,
Ian Wild
PlusNet Customer Support
