http freeze
http freeze
anyone else get http web pages freezeing and after 3 miniutes it starts to work again
this is pithing me off
maybe time i change isp
RE: http freeze
No problems here. In fact my both my downstream and upstream speeds are consistantly faster than the figures for Nildram during Feburary on ADSLGuide.org.uk
RE: http freeze
nochance me changeing isp i was lieing
the customer support is second to none
looky here
2003-03-20
23:37:33 Comment By: You
[Support Wizard Journey]
[Wizard NOT followed]
[Technical]
[Customer did not raise this query using the Contact Wizard, please investigate if we need to improve the wizard accordingly]
[Additional Information]
Hi i have recently seen NTL are limiting customers downloads to 1 gig per day , is this true and will you be doing anything like this?..
question 2 is when will the 1-2meg conections be ready for home users...if so??
thanks and keep up the good work
chrisSmiley Open
2003-03-20
23:59:31 Comment By: Dave Watson
Customer Support Centre Hi Chris,
1, We have no plans to cap bandwidth on any of our products.
2, We are looking in to this and will be making a announcements in due course.
We expect the time scale to be around summer.
Regards,
Dave Watson
look at the times
took 30 mins to answer my questions
plusnet are the best
RE: http freeze
Wait until it's a technical query, then it takes time. Yours was a simple routine question.
As for your problem, have yout ried programs like AdAware, as Spy/AdWare tends to play these sorts of tricks
RE: http freeze
hello phillip
this is after a fresh install of windows and still http freeze 2 miniutes long
thanks m8
chrisSmiley
RE: http freeze
Hi Chris,
Have you tried changing the DNS settings used by your machine?
As a test, can you try changing these to:
212.159.13.49 and 212.159.13.50
These DNS servers are currently in testing and may prove to be faster for you. I would be most interested in your feedback!
Regards,
Ian Wild
PlusNet Customer Support
