.htaccess
.htaccess
Is there way to specify an error page in the same root directory as the actual .htaccess file?
I assumed this would work:
ErrorDocument 404 error404.html
But it doesn't work. It seems to interpret the error404.html as a line of code and displays it, literally, on screen.
Any ideas?
David.
1 REPLY
.htaccess
is the error404.html file in the same directory as the .htaccess file ? if not then you will need to add the directory structure in front of the file . i.e. /errordocs/error404.html
also the error document must be over 512 bytes or it will not be displayed by microsoft windows
