how to check line attenuation with a SpeedTouch 330
mate of mine is asking how to do the above - I dont know cos I dont have BB yet!!!
Not all modems or routers have the ability to give you the line information.
If it does it should be found in the setup menu.
hi there if you follow the info on this page should get you the info you need
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=general&Number=1615147
that seems to be the best way to get these figures from a frog.
doh!!
Steal someone else hint and get rumbled posting it back to a dead discussion
sorry
