how many phones can I run off one filter?
sinewave
subject says it all :-)
Just thinking I can have one filter at the main BT socket and run all phone extensions from that - or does that somehow "overload" the filter.
madswitcher
You are better off using a filtered faceplate on your master socket. which will then allow you to run all your extensions without the dongle filters. You can get them from various places - do a Google on NTE5.
Cheers, Mike
chymorva
Re: how many phones can I run off one filter?
You are absolutely correct in your initial thinking. No it does not overload the filter. Smiley
See my tutorial here
You can have ALL of your phones of the one filter if you wish.
