how long does it take to set up email address
hi im just wondering how long will it take to set up email address in outlook 2003
as im getting a error saying unable to log onto incoming mail server also a box pops up saying password username and i put it in but its incorrect so does plusnet have to sort it out at there ifso how long does it take to set up
LiamM
When you setup your email account in Outlook you first need to have that account setup at Plusnet's end. Outlook doesn't actually setup the account for you, just logs onto an account setup with Plusnet.
Under "My Account" on the left is the option "Email Settings". Use this to create a mailbox.
i can send emails via outlook but im not recieving them please reply back asap
What are you using for the outgoing SMTP server? It should be relay.plus.net.
What errors are you getting (you need to post them in full).
Have you read through the help & support section on Emails?
it is relay and i am not getting any error messages
There is trouble with the emal servers this morning. I've had a few messages saying Outlook cant connect.
Word_Warrior
Are you using the correct Account ID info in receiving mail section?
it should read
Username+mailbox name
e.g. plusnet+webmaster
Common error we all do it.
Oh it's just me then. Cheesy
Word_Warrior
it should read
Aologies for the duplicate pressed twice while in a portal slowdown. Couldn't delete it.
