how do you raise a ticket
could someone tell me how i can contact plusnet without having to go throught broadband fault checker
As from reading your other post, it sounds like you have a braodband fault, then you should use the automated fault reporting process.
Chilly
Plusnet Leader
Plusnet Leader
You can always call our support team on 0845 1400 200 and they can raise the fault for you if you can't go through the fault checker Cheesy
