hotmail and windowsupdate not working for 3 days now...
Since friday night, i have been unable to get windows update to work properly (It gets to 100% after ages so most likely times out, then says no updates available)
I hve also had problems with hotmail as well, i can login ok , but if i try to change folders or open mesasges, it just seems to hang and doesnt load.
Ive even tried reinstalling windows several times/only put in bare minimum hardware to see if that solves windows update etc but it still doesnt work Sad
My last port of call is that its maybe plusnet?
I can ping the servers ok, but it seems that it falls over when it has to use SSL ie hotmail/windows update.
Any ideas?
cheers
crunchie
1 REPLY
how verrrrrrrrrrrrry strange, literally just after posting this, it started working again LOL!
