help please im throttled at 500kbps
zambezi
hi there,
was wandering if there is any way of getting the exchange to update quicker as it says my maxium connection is 500kbps
but im connecting on my router at 7904 kbps
i had a few power cuts yesterday so mu router was off a couple of times but then the above happend
im surfing at 127kbps
or do i just have to reconnect once a day for 3 days to get it back ?
any help would be appreciated
1 REPLY
Looks like BT Max has clobbered you and you will have to go thru the reboot process for a few days.
Hopefully you havent been caught by the Plus problem.
