help on sar 110
help on sar 110
Need brains, mine's dead. Here's the settings on the 10/100 network tcp/ip settings.
ip address 192.168.7.2
subnet mask 255.255.255.0
default gateway 192.168.7.1
pref dns 212.159.11.150
alt dns 212.159.13.150
Lights showing on router are, power,adsl (constant), pc and intermittant tx.
Whenever i type in the server address http://192.168.7.1/ i get a message "not conncted to the internet".
This is driving me potty what on earth am i doing wrong.
unlike the zoom adsl modem there seems to be no intallation file anywhere on the cd.
All help gratfully recieved.
help on sar 110
Is this a new installation or has router worked before? Assuming new, you shouldn't need any setup files (you were lucky, I didn't even get a CD). What version of Windoze are you running?
Can you ping the router from a DOS prompt?
Have you checked the LAN settings in Internet Explorer? Tools, Internet Options, Connections Tab, LAN Settings - the check box should probably be set to "Automatically Detect Settings"
Sorry, this is all questions, not answers but will help if I can. I'm quite pleased with my 110 - once you've prevented the world from logging into it.
Cheers,
Spenser.
jberry
help on sar 110
Make sure that you have gone into the connections tab of internet options and changed it to "never dial a connection" or your machine will try to dial up when you view web pages.
Regards,
help on sar 110
Thanks for the replys have alterd settings as requested, will let you know what happens.
O/S win98 SE, new istallation, cannot ping router cos no connection.
Driving me nuts trying to figure this out.
help on sar 110
tried the mods suggested but it just wont connect to the net.
but my old zoom adsl modem gets in every time, getting to the stage that i wished i'd never bought the thing, too much hassle.
I'll stick with the modem, much easier. Smiley
help on sar 110
reset,
What messages do you receive when you issue the ping command as it sounds like a network card setting/driver problem.
Darren
help on sar 110
sounds like something i did when connecting my router- had the wrong type of cable plugged into it - i had a crossover cable in instead of the other type ( dno what the difference is, but i pulled the other one in and it connected str8 away Cheesy
try a different cable ( the cables i used both had same heads so maybe sopme one could clear this up - ie which cable i was using and which i am using now )
( ps i only connected on computer to it)
help on sar 110
Just for your own and other readers information a "crossover cable" has the transmit and receive pairs crossed over at one end (Usually but not always marked with a X at the crossed end)
You would only use a crossover cable for connecting 2 PCs Directly to each other and not if you were using any sort of Hub.
help on sar 110
Most (but not all) crossover cables are helpfully marked. A good tip if you're BUYING cables is to choose a different colour for cross-overs. If you're using the (inadequately short) cable that came with the router you should be ok - maybe you can re-jig / move things for a test? The actual connections for the ends (RJ45 connectors) may be found here
http://www.hardwarebook.net/cable/index.html
almost all cables do follow a set colour code so you can usually identify a whether you have a crossed or flipped cable by holding the ends side-by-side and looking at the colours.
Umm, Win 98 seems to ALWAYS need a re-boot if you change ANY of the TCP/IP settings - even a DNS IP address - God knows why? and the first step really is to get "ping" working.
Open a command prompt and type "ping 192.168.7.1"
I use a different address but you should get results like this:-
Pinging 172.16.0.2 with 32 bytes of data:
Reply from 172.16.0.2: bytes=32 time=1ms TTL=63
Ping statistics for 172.16.0.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1ms, Average = 1ms
If you DO then it's almost certainly Browser settings that are at fault.
If NOT then it's either hardware (PC, Cable or Router), TCP settings / configuartion or a faulty driver.
I think I spotted a thread on this Forum from someone who's router was NOT set to factory defaults and this was blamed on the unit being a "sample" subjected to extended factory tests. There was definitely another (more recent) thread which dealt with restoring defaults by connecting to the PC's serial port (a cable is supplied) and using Hyperterm to reset the router. May be worth a try.
Good luck. Sounded like you'd had enough the other night. Smiley
help on sar 110
You'd also use a cross-over cable to connect two hubs Smiley
help on sar 110
Not always. Some hubs have a special port that has a built in crossover.
help on sar 110
Yes,
An uplink port, it can usually switch between being normal or cross over.
Some hubs and switches are even autosensing.
I use a Netgear DG814 router which has a built in switch with autosensing capabilities.
Chris
help on sar 110
Tee Hee.... this is fun, though I think we may be straying SLIGHTLY from the original thread.... WITHOUT Auto-Sense, you'd certainly need a cross over cable to connect John's Special Port to a PC or SAR110. Cheesy PS - Parenthood.... who'd put up with it? I am now obliged to go and "supervise" my daughter's friends as they've built a water slide in the garden... they're all 18 but the combination of wet plastic an bikinis can be more DANGEROUS than network cables.
Mark_Dowd
help on sar 110
...has the transmit and receive pairs crossed over at one end (Usually but not always marked with a X at the crossed end)
John.
Surely a crossover cable is symmetrical, or am I being a bit simple? :?
help on sar 110
18 you say?
If you ever need a hand supervising let me know! lol
Chris
