help needed to set up router
Hi
I have just got a netgear DG834 modem router and I have no experiance of setting it up, I need to know the multiplexing method VC based or LLC based, encapsulation PPPoA or PPPoE and do I need to put anything in the service name box, and is there anything else I should need to know.
1 REPLY
It has an auto-setup option.
Connect to the netgear and click the setup wizard link (top left). Set the country and language, make sure auto-detect connection type is set to yes and click next.
At some point you just enter your plusnet login and password and you are done.
This is explained in the manual and there is also help available on the router itself.
