help me plz!!! about the network optimiser
as plus.net recommand, i download the network optimiser. when i try to use it, it's showed:
sorry could not find any supported adapters. so i can't use it. what's problem is this? my network card?? or something.
someone can help me?
thanks very much
1 REPLY
fonejacker
RE: help me plz!!! about the network optimiser
Hi There,
The network optimiser is somethign we can't offer direct support on, as it is provided by a third party (BT).
If you are using a router / network card then changing the MTU is less likely to have an impact, but without having a look at your machine, or getting a lot more detail from you about hte setup, it is going to be impossible for anyone to diagnose this.
Regards,
Ian Wild
PlusNet Customer Support
