garbage speeds
garbage speeds
whats up with my speeds they are crap http://www.adslguide.org.uk/tools/speedchart.asp?id=95cc56b5f75f193dd595cc56b5
2 to 3 weeks now of this...... lets have an answer plusnet
garbage speeds
Can you click Start > Run > Type "cmd" > in the box type "tracert www.linx.net" and copy + paste the results. See where the weak link is.
And can you also tell us what connection equipment you are using (modem/router, ethernet/usb, etc.)
garbage speeds
my router is an efficient networks 5861 and my network card is a realtek RTL8139.
as you can see i'm getting stunning pings from the traceroute below
Tracing route to www.linx.net [195.66.232.42]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.254.254
2 147 ms 32 ms 38 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 * 130 ms 192 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
4 32 ms 44 ms 37 ms gi5-0-4.pth-gw2.plus.net [195.166.129.22]
5 97 ms 68 ms 144 ms ge0-1-0-0.er0.tclon.uk.easynet.net [195.66.226.4
3]
6 52 ms 71 ms 37 ms ge0-1-0-0.br0.tclon.uk.easynet.net [195.40.4.74]
7 31 ms 44 ms 59 ms ge0-0-0-0.gr0.tclon.uk.easynet.net [207.162.199.
7]
8 33 ms 59 ms 29 ms fe0-0-0.gr3.tclon.uk.easynet.net [207.162.199.2]
9 104 ms 80 ms 98 ms fa2-0.easynet-linx.tr3.tcm.linx.net [195.66.248.
77]
10 174 ms 238 ms 173 ms e2-2.collector.thn.linx.net [195.66.248.241]
11 86 ms 107 ms 50 ms piper.linx.net [195.66.232.42]
Trace complete.
garbage speeds
Have you tried switching off your router for about 10 seconds and then switching it back on? This usually fixes problems of this nature.
