fix my usage limit
fix my usage limit
fix my usage limit i download only 3GB per month wtf
plusnet system broken
Total usage:58.6GB
holdtight
fix my usage limit
There are certain ways of asking for help and having some manners and not swearing will go a long way towards helping yourself
I notice from all of your previous posts that you are seriously lacking in manners and all you will find is yourself getting ignored or again by your previous posts banned
Plusnet Staff
Plusnet Staff
fix my usage limit
If the usage isn't your usage then I would strongly suggest running a full virus and spyware scan and if you have a wireless router ensuring that it is secured and that no has access to it. The usage could easily have been doneby someone else connecting to your wireless connection, possibly in error.
fix my usage limit
@ Dave
I believe that our friend here doesn't use a router, as he has intimated (in his own unique way) in the past that he uses a modem.
Something tells me (from his previous speed problems in the past) that as you suggest, he might have some spyware or something of that ilke on his machine - he might just not have found it yet.
