figures off a voyager 105
tonka
hi guys can anyone tell me how to get the noise margin and line attenuation figures off a bt voyager 105 modem looked everywere with no luck,cheers in advance.
Open the "Voyager 105 ADSL modem Control Panel" (double click the taskbar icon) , then "Status" which will give you a grey box with some line data in it. Then press control-F1 and you'll get a whole bunch of menus -- click "DSL Link", and the SNR/Atten are at the bottom. The significant figures are in the "local" column -- what other modems and routers call "downstream"
EDIT: the link in your profile seems a bit broken
tonka
cheers mate,if you mean my website link its fixed now.
BTW tonka, you will struggle to get it to work logged on as an" limited user". You just need to login to an admin account on your comp first.
tonka
can you explain a bit more what you mean i have managed to get the figures of my modem.
If you allready have got them, then what I said before doesnt matter m8.
