extermal pop3 accounts using webmail?
How do I set up external pop3 accounts using webmail ?
I trying to use webmail to access my orange mail as I don't like their webmail. However I'm unsure what the settings for "Utilities\Multi Accounts" should be
1) UserName - OK
2) Hostname - What should I put here? Their IP address?
3) Mailserver - OK pop.orange.net
I thought the settings would be
1)Account name
2)password
3)pop server
The help doesn't seem to provide any clues
cheers
1 REPLY
If you have an email mailbox called fred@btinternet.com which you login to using the username fred123 and password 123fred and use the POP3 server mail.btinternet.com you use the following details:
Username: fred123
Hostname: btinternet.com
Mailserver: mail.btinternet.com
Type: if the Mailserver specified is a POP3, select POP3. If it's an IMAP server, select IMAP.
This creates a new entry called fred123@btinternet.com (this is not your actual email address it is just Username@Hostname), which when you click it will ask for your password.
So:
Username is what you login with to get to your mailbox and not necessarily your mailbox name.
Hostname is the domain part of your email address (the bit after the @)
Mailserver is just that the POP3/IMAP server.
Note: there was a problem with Usernames containing @ (i.e. you actually login with a username like fred@domain.com) which did not work. I'm not sure if this has been fixed yet.
