exchanges and speeds
Hello
Is there anyway of finding out the max speed an exchange can handle?
darrenf
Nope.
However almost all will support 2Mbs speeds as they use pretty much the same hardware. If your looking for info on faster than 2Mbs then it does not exist (yet).
Also it is more likely your line quality that limits your speed rather than the exchange.
speed
i was previously told my line couldnt support broadband, then last year, after bt upagrdes to speed, i managed to get 512. iknow BT are now making more upgrades to speed therefore if i upgrade my connection to 2mb, i should then find out what the maximum speed is on my lineHuh am i right? i guess if it can't be upgraded you'll just refund the upgrade fee.
I suggest that you wait until MaxDSL comes in next month, you will then be able to upgrade your line to the maximum possable speed without additional charge.
Chilly
I found this site was pretty good....
http://www.samknows.com/broadband/checker2.php
