email server and autoturn - mail loop
kissack
I have recently set up a home mail server and am happy with the results. I understood that if it went off line +Net mailservers would retain the message until my mail server was up. To test this, i stopped my mail server and sent a test message - it bounced! Not what I expected.
Here is the message (with yahoo and plus accounts altered):
X-Apparently-To: private@yahoo.co.uk via 217.146.176.26; Sat, 26 Feb 2005 12:54:32 +0000
Authentication-Results: mta130.mail.ukl.yahoo.com
from=ptb-relay03.plus.net; domainkeys=neutral (no sig)
X-Originating-IP: [212.159.14.214]
Return-Path: <>
Received: from 212.159.14.214 (EHLO ptb-relay03.plus.net) (212.159.14.214)
by mta130.mail.ukl.yahoo.com with SMTP; Sat, 26 Feb 2005 12:54:32 +0000
Received: by ptb-relay03.plus.net with local (Exim) id 1D51Sq-000MMh-AB
for private@yahoo.co.uk; Sat, 26 Feb 2005 12:54:32 +0000
X-Failed-Recipients: allan05@mydomainismannin.plus.com
Auto-Submitted: auto-generated
From: Mail Delivery System <Mailer-Daemon@ptb-relay03.plus.net>
Subject: Mail delivery failed: returning message to sender
Date: Sat, 26 Feb 2005 12:54:32 +0000
Content-Length: 1081
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
Too many "Received" headers - suspected mail loop
------ This is a copy of the message, including all the headers. ------
Return-path: <private@yahoo.co.uk>
Received: from [212.159.3.9] (helo=autoturn.force9.net)
by ptb-relay03.plus.net with smtp (Exim) id 1D51Sq-000MMe-7b
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:32 +0000
Received: (qmail 32345 invoked from network); 26 Feb 2005 12:54:31 -0000
Received: from ptb-relay01.plus.net (212.159.14.212)
by autoturn.force9.net with SMTP; 26 Feb 2005 12:54:31 -0000
by ptb-relay01.plus.net with smtp (Exim) id 1D51So-0004ji-DS
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:31 +0000
Received: (qmail 32299 invoked from network); 26 Feb 2005 12:54:29 -0000
Received: from ptb-relay03.plus.net (212.159.14.214)
by autoturn.force9.net with SMTP; 26 Feb 2005 12:54:29 -0000
by ptb-relay03.plus.net with smtp (Exim) id 1D51Sn-000MLv-RE
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:29 +0000
Received: (qmail 32292 invoked from network); 26 Feb 2005 12:54:29 -0000
by ptb-relay03.plus.net with smtp (Exim) id 1D51Sm-000MLf-BK
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:28 +0000
Received: (qmail 32279 invoked from network); 26 Feb 2005 12:54:28 -0000
by autoturn.force9.net with SMTP; 26 Feb 2005 12:54:28 -0000
by ptb-relay03.plus.net with smtp (Exim) id 1D51Sl-000MLX-Tc
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:27 +0000
Received: (qmail 32273 invoked from network); 26 Feb 2005 12:54:27 -0000
by autoturn.force9.net with SMTP; 26 Feb 2005 12:54:27 -0000
by ptb-relay03.plus.net with smtp (Exim) id 1D51Sl-000MLT-Cp
Received: (qmail 32259 invoked from network); 26 Feb 2005 12:54:27 -0000
Received: from ptb-relay02.plus.net (212.159.14.213)
by ptb-relay02.plus.net with smtp (Exim) id 1D51Sj-000PZx-Jl
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:26 +0000
Received: (qmail 32235 invoked from network); 26 Feb 2005 12:54:25 -0000
by autoturn.force9.net with SMTP; 26 Feb 2005 12:54:25 -0000
by ptb-relay01.plus.net with smtp (Exim) id 1D51Sj-0004iJ-6P
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:25 +0000
Received: (qmail 32223 invoked from network); 26 Feb 2005 12:54:25 -0000
by ptb-relay03.plus.net with smtp (Exim) id 1D51Si-000ML0-RI
for allan05@mydomainismannin.plus.com; Sat, 26 Feb 2005 12:54:24 +0000
Received: (qmail 32216 invoked from network); 26 Feb 2005 12:54:24 -0000
by autoturn.force9.net with SMTP; 26 Feb 2005 12:54:24 -0000
by ptb-relay03.plus.net with smtp (Exim) id 1D51Si-000MKp-G6
Received: (qmail 32209 invoked from network); 26 Feb 2005 12:54:24 -0000
Received: from web26404.mail.ukl.yahoo.com (217.146.176.28 )
Received: (qmail 79789 invoked by uid 60001); 26 Feb 2005 12:54:24 -0000
Message-ID: <20050226125424.79787.qmail@web26404.mail.ukl.yahoo.com>
Received: from [81.174.133.xxx] by web26404.mail.ukl.yahoo.com via HTTP; Sat, 26 Feb 2005 12:54:23 GMT
Date: Sat, 26 Feb 2005 12:54:23 +0000 (GMT)
Subject: test to downed mail server
To: "me" <allan05@mydomainismannin.plus.com>
Looks to be looping around the +Net servers instead of waiting in autoturn?
Can anyone shed any light on what is going wrong, so I can fix it?
From the looks of that, there is a mail loop.
I suspect this will occur until the DNS server catchup properly.
How long ago did you make the SMTP changes at PlusNet?
kissack
DNS was changed for mannin yesterday morning, but the day before for my hosted domain that also fails in the same way (loops when mail server is down).
Surely that is enough time for the DNS to propogate within +Nets own servers (as the loop is internal to +Net)?
Should have been plety of time.
I can only suggest raising a ticket.
kissack
thanks. I'll do that
