email address
tonka
email address
is it possible to have another email address on the same computer as my missus want's a email address of her own.
glyndev
email address
this is easy to do.
in your email software just create a new user account and enter the details for your wife's email account
tonka
email address
had a look in there couldnt see where you do it doh!!!!.
cossey
email address
Tonka, it may help if you say which email client you're using.
Outlook Express?
Outlook?
If you're using Outlook Express you may want to look at the 'Profiles' options. Unfortunately I haven't used Outlook Express for some time so can't help too much.
If you both use the same PlusNet account then you'll need to set up a mailbox for the wife to receive her emails into.
Hope that's of some help
tonka
email address
using outlook express mate can't find profile's mind you have had quite a lot of beer over xmas.
glyndev
email address
File ... Identity ... Add new identity.
Then follow the instructions with regards to the username, mail server, username etc..
Hope this helps
email address
use thunderbird instead of OE , its more secure and more reliable Smiley
email address
Also have you actually created a named mailbox for here to use on the Plusnet portal - see Email settings on the left. Just create a new mailbox, give it a password then setup a new account in OE and use username+mailboxname and the password you set to collect email from that mailbix.
Also look at the plusnet help pages on email, they explain what to do in detail.
tonka
email address
cheers folks always helpfull.
