dsl stats query
nogginthenog
dsl stats query
downstream margin 15 db
upstream margin 22 db
downstream l.a 9
upstream l.a 4
applogies its vista i am learning,are these stats decent?
help appreciated
dsl stats query
The operating system won't make the slightest difference to your router stats.
Is difficult to say without knowing your sync speed, but those stats look good to me.
nogginthenog
dsl stats query
thanks for the reply,i'm on a linksys wag354g dsl path mode says fast i presume that means im not interleaved downstream is 8128, and getting around 5-6 kbps on bt speedtest. any tips on how i can improve this?
many thanks
dsl stats query
Do you mean 5000-6000kbps, or literally 5-6kbps?
nogginthenog
dsl stats query
sorry my mistake my current stats on speedtest
Plusnet Staff
Plusnet Staff
dsl stats query
That's probably about as fast as it goes. With an 8128kbps sync speed the absolute maximum throughput speed is 7150kbps. You'll occassionally see speedtest results around 6.7 - 6.9Mbps but not much more because of overheads, but 6 - 6.5Mbps would generally be about the fastest, especially in an evening. Might go up a touch more overnight or in a morning.
nogginthenog
dsl stats query
thanks for the replies Cheesy
Plusnet Leader
Plusnet Leader
dsl stats query
No problem.
Any more questions then give us a shout Cheesy
