dsl line problem.
dsl line problem.
Hey, this totally sux.
Got our router today, connected both of our P.C's, hooked the cable into the microfilter, and the line, and everythings fine, but it jsut won't pick up our line, n the DSL monitor on the router's flashing like hell!
Nebody know how to solve this?
dsl line problem.
Verify you have the correct filter setup. See the Wiring and filters tutorial for help
Plusnet Staff
Plusnet Staff
dsl line problem.
Take a look at the following tutorial if that doesn't help then either raise a ticket or give us a call and we can raise it as a line fault and run some remote diagnostics on the line.
thx
hey, thx dudes, I'll prob try it l8r or summit.
:? me is verry tired, and main socket alll the way in other room,
I'm very lazy........
