download speeds through the floor
tonight my download speeds have been through the floor. 70kbps, normal speeds 450 to 550kbps I have re-booted and my line stas are stable. No contention issues on exchange. Max'ed in may sorted by end may so it's not retraining. MSR on PN 7000kbps router on 7392kbps.
Is anyone else having trouble tinight with extremely poor speeds. never done this before.
Any one suggest a reason.
A
DSL Status : Up
DSL Modulation Mode : GDMT
DSL Path Mode : FAST
Downstream Rate : 7392 Kbps
Upstream Rate : 448 Kbps
Downstream Margin : 6 db
Upstream Margin : 23 db
Downstream Line Attenuation : 47
Upstream Line Attenuation : 25
Downstream Transmit Power : 0
Upstream Transmit Power : 0
PVC Connection
Encapsulation : RFC 2364 PPPoA
Multiplexing : VC
QoS : UBR
Pcr Rate : 0
Scr Rate : 0
Autodetect : Disable
VPI : 0
VCI: 38
Enable : Yes
PVC Status : Applied
http://www.dslzoneuk.net/speedtest/speedtest.php?id=1301882870
http://www.speedtest.bbmax.co.uk/ Last Result:
Download Speed: 1006 kbps (125.8 KB/sec transfer rate)
Upload Speed: 375 kbps (46.9 KB/sec transfer rate)
PlusNet Speed Test
Your current speed is:
959.10kbps
Which means you can download at 119.89 KB/sec. from our servers.
BT
The speed test has completed on test server test.speedtester.bt.com for user 01******** and you have downloaded a 1.7Mb file at a speed of
784 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
I thought my speeds were bad, yours are even worse.
Reasuring thing is they are improving slowly.
Only took me an hour to upload a 78mb file Sad
back up to normal this morning?
someone at my exhcnage must have been downloading a heck of a lot last night.
or PN's balancing was out. Could pn's load balancing on the pipes cause this.
I know it's unlikely but could it in theory?
A
If it was contention then a BT speed test would have shon this up. If it happens again do the speed test and if that is normal raise a question to report a speed fault.
cheers,
of on holiday for a few weeks. Will test more when I come back. should I disconnect for the 2 weeks or leave the router running. will it make a difference?
A
