download problem
download problem
Have got a message on my screen from the internet explorer - \\192.168.0.1 is not accessible. contact abminstrator. All I know is i can not download anything from a P2P site I.e soulseek, Ares, or through a bittorrent everythings there but nothing will happen, can anyone out there help. have turn off anti virus software firewall but there's nothing that I know that can make my computer download work? Sad
Alecto
download problem
Could you download from it before?
What have you changed in the meantime?
How long has it gone on for?
Have you been banned from it?
May just be that the site or tracker is down.
If 192.168.0.1 is the site, then I can't get it either, but it sounds like a router address..Try rebooting your router.
Or you could try posting the url here so somebody else can try it.
download problem
how do i reboot a router
Alecto
download problem
Turn it off and turn it off at the mains.
Do the same for your computer.
Turn them back on again and they reset themselves, or "reboot".
download problem
I that doesnt help goto start/run type cmd press return then type ipconfig /renew.
The type ipconfig /all and post the reply. try ping 192.168.0.1 you should get a reply
The 192.168.0.1 is the router address if you dont get a reply there is a fault with the router, your network cable or your pc isnt geting th eip correctly
