dim
dim
Pardon me for being a bit dim, but why do they send 2 microfilters when there is only 1 ADSL cable to connect.
I have 2 phones runnining off the main BT socket via i doubler, obviously 1 microfilter goes before the doubler (with the 2 phones connected) and the ADSL lead goes into the socket on the microfilter.
So what the hell do you do with the other one, just can't figure it out.
Reset
RE: dim
you don't have to do anything with it! it's provided so you can connect 2 phones if you don't put a filter on before the splitter.
on the other hand, you could give it to me!
RE: dim
It is so when the connection does not work they can ask you to try the other filter in case there is a fault with the filter :cheese:
Still has not solved my intermitent connection problem (5 days and running)Sad
