difference between www and non www
Daft question.
Externally (i.e. outside my home network)
if I access http://marksward.plus.com I get to my home server.
if I access http://www.marksward.plus.com I get my plusnet hosted webpage.
Why the difference and how can I make the www go to my home server instead.
Alternativly I have another domain hosted by plus (not billing) can I get this to point at my home server instead?
I'm on premier with static ip.
Mark
csogilvie
Re: difference between www and non www
username.plus.com points to your static IP address, so thats where you end up.
www.username.plus.com points to PlusNet's Homepages server.
Depends on what facilities your current host has... but if you can point www.domain.ext and domain.ext to random IP addresses (A Records) or to hostnames (CNAME) then you could set it to your static ip.
One other way to redirect www.username.plus.com to username.plus.com is to have a .htaccess file in your webspace that contains something like:
Redirect / http://username.plus.com/
Hope thats what you're after!
thanks for the replies.
Currenlty changing the A record on my other domain to point at my server will see how it goes!
mmm
yesterday for one of my other domians hosted by plus I set the:
rightfield to www
the type to A
the leftfield to my static IP
Today the url is still taking me my plusnet homepage
does that sound correct, is it just taking a while for dns to update?
Must be right its now working!!!!
Thanks for all the help
DNS can take up to 48hrs to reflect its changes.
