db loss of my line
db loss of my line
is there a way to check the level of db loss on my line,any online checker or do i have to phone bt?
db loss of my line
BT will not do it and even if they did you don't get the results as far as I know. Raise a contact us ticket and ask PlusNet to do a woosh test saying you are looking to upgrade and want to know if it is possible. Also say you don't want the test results passed on to BT.
Some of the routers give you this info as well. What are you using for ADSL connection?
db loss of my line
my router is an efficient networks 5861
