connection?
connection?
did anyone experiance any probs about 5 mins ago ,i couldnt connect ,username and password were accepted,was the ppp link was down?,alls ok now tho
connection?
I did notice something but I put it down to the fact that I was downloading a load of updates for Win98se at the same time as reading the forum.
All seems ok now though as you have said.
connection?
By the way your Avatar is trying to call your own machine so can't be seen by anyone else but you.
The file needs to be uploaded to your webspace and called from there to make it work.
connection?
hi again for a few secs the ppp link went down i checked the solwise config page and thats what it said ,about the avatar ,i cant see it either ?
connection?
The link you have for your Avatar is below
http://c:mydocuments/rippeddvd/horror67.gif
C: is on your machine.
You need to upload the file "horror97.gif" to your webspace and then call by using
http://www.pjsavant.plus.com/horror97.gif
This is assuming that you put it directly into the htdocs folder which is the root directory of your webspace.
If you insert another directory then you will have to include that in the URL.
