connection dropping every couple of mins
as title says...
eres my log its seriously wrong somewhere
23:28:31 GMT Wed Jan 5 2005
STATUS ALARM : PPP Interface Up : Interface - ppp-0
STATUS ALARM : IPCP Successful : Interface - ppp-0, Local IP Address - 81.174.151.25, Gateway IP Address - 195.166.128.123
STATUS ALARM: PPP Authorization Successful : Interface - ppp-0
23:26:28 GMT Wed Jan 5 2005
WARNING : PPP Interface Down : Interface - ppp-0
WARNING : PPP Authorization Failed : Interface - ppp-0
23:24:43 GMT Wed Jan 5 2005
23:22:52 GMT Wed Jan 5 2005
STATUS ALARM : IPCP Successful : Interface - ppp-0, Local IP Address - 81.174.151.25, Gateway IP Address - 195.166.128.6
23:22:37 GMT Wed Jan 5 2005
23:1:56 GMT Wed Jan 5 2005
23:1:41 GMT Wed Jan 5 2005
22:56:30 GMT Wed Jan 5 2005
22:56:15 GMT Wed Jan 5 2005
22:53:44 GMT Wed Jan 5 2005
22:53:30 GMT Wed Jan 5 2005
22:43:38 GMT Wed Jan 5 2005
22:43:21 GMT Wed Jan 5 2005
22:38:40 GMT Wed Jan 5 2005
22:38:39 GMT Wed Jan 5 2005
22:38:23 GMT Wed Jan 5 2005
22:38:4 GMT Wed Jan 5 2005
22:36:58 GMT Wed Jan 5 2005
22:36:41 GMT Wed Jan 5 2005
22:24:19 GMT Wed Jan 5 2005
any ideas ,many thanks
as this is getting ridiculous,al this after ive just asked for an upgrade to a 2 mb line Cry
What ADSL hardware are you using and does it report line statistics like attenuation and signal to noise values. If so please post these.
Also try connecting directly to your BT master socket.
Try will all other phones disconnected, also try without a filter on the ADSL modem if you can.
Try a different ADSL filter.
Do the BT 151 automated line test and see if it reports any line fault.
Do you hear crackling on th eline when you pick up a phone and hear dialtone. Do you still hear it when you press 1? If so report a BT line fault and see if they can clean it up as that may be causing your disconnects.
Go though the troubleshooting pages on the Plusnet help and in the tutorials forum.
Using a good microfilter can sometimes cure this type of problem. I recommend the Excelsus Z-420UK-A Dynamic ADSL Microfilter or the XF-1e Professional ADSL Microfilter.
Failing that, contact Plusnet and ask them to do a Woosh test -although if you have an order in place this can't be run until that is completed.
ok cheers just able to connect now will go thru test now,thanks
Moderators note by John (johnessex) Duplicate post deleted.
I had the same problem months ago and stealthing the router made no difference either. All it was for me was some kick-a*s splitters at £9 a piece, worth a try and connection has never dropped since
Try here:
http://www.adslnation.com/phpapps/catalog/default.php?cPath=24&osCsid=cd955fc2b8405258f369ab0a57b0d4...
That one is cheaper via my previous link.
since my post at 12 and petes reply i done a line check with bt and all fine,i went out for 4 hours and left pc on downloading some stuff and never had 1 disconnect,been browsing tonite now for 2-3 hours with not 1 prob very strange but welcome,wethet thre was a prob wwith line and bt kept quiet about it,,, Wink
