connect from anotehr location
just wondering are you able to connect to your plus net adsl account from another location which has a adsl line installed, or is my username just for my line.
thanks
1 REPLY
You can connect to PlusNet from another ADSL line, provided the owner of the line uses PlusNet ADSL too.
BT restrict the REALM that a line may login to, but not the username.
PlusNet use 2 realms, @plusdsl.net and @plus.net. Your realm must also match there realm for this to work.
