confused about speeds
bt speed test is consistantly as below
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8096 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1913 kbps
plusnet speeds
14-03-2007 20:45:39 731.8
14-03-2007 20:16:41 1314.2
14-03-2007 20:15:33 1235.4
14-03-2007 09:14:13 1972.3
13-03-2007 21:05:02 555.2
13-03-2007 21:03:46 521.3
where bt says IP profile for your line is - 7000 kbps
plusnet highspeed says IP profile for your line is 2000 kbps
my router says and is constant at 8096 448
can any one explain what all this means please?
Plusnet Staff
Plusnet Staff
Looks like this
is set incorrectly. I've corrected this for you now, you may need to disconnect and reconnect for the change I've made to take effect but should then see an increase in speed.
thankyou
Plusnet Staff
Plusnet Staff
Fixes: 159
The speed your router reports is your sync speed (8096), the BT Wholesale equipment generates delta reports based on this to alter your IP profile (7000), your throughput (1913) will never be above the IP profile speed.
Edited to add this link which has some good info on it
http://portal.plus.net/central/forums/viewtopic.php?t=52181
 Chris Parr
 Plusnet Staff
When I go to connection settings it says
Your current broadband speed is 500 Kbps
It used to say 1,000Kbps.
I'm on DSL Max.
