configure my netgear 834gt
hi i have just joined plusnet from nildram and need to configure my router i have changed the settings that i think are correct but when i do a speed test on plusnet i get a big fat ZERO download.I cannot see what other settings to change i need to do it quickly before my nildram shuts down.
Hi there
Welcome to the forums.
Can you try an ADSL Guide Speed Test.
The Plus Net test can prove problematic at times.
Try AG and let us know how that goes.
thanks for that i had a result as follows is that good for plusnet 2meg?
http://www.adslguide.org.uk/tools/speedchart.asp?id=6fb37854106fe6114fd73d18f1f
cheers
Those speeds look fine to me.
You could have a read at this page from Kitz, which will explain tweaking and getting the most out of your speed.
