conexant pci modem
cookie141
conexant pci modem
Hi
Running Win2000 pro
Having trouble reinstalling accessrunner dsl
the wan adapter installs ok but the runner doesnt...
when the adapter has installed i have rebooted straight away as advised
but to no avail the runner does not seem to install...nothing on the desktop
any ideas round this problem please..
thanks cookie
conexant pci modem
Any error messages?
Have you checked for updated drivers or software versions?
I assume this was working fine before - i.e. this is not the first time you have installed it on Win2K?
conexant pci modem
hmm.. i had this problem a while back that was only because i downloaded the "latest" drivers from dynamodes website - the drivers claim to be pci but are infact usb, which is rather annoying anyways to fix it remove all traces of the previous driver then upon install (assuming you use the .50 drivers) goto specific location and goto the folder - select the driver and your done
