checking for Jupiter or Redback connections
I saw a posting on how to check if you are connected to the Juniper or Redback pipeline but can't find it. My connection seems rather slow so I would like to find out how to check. I have got a ping utility but can't remember how you can recognise whether it is Juniper or Redback
Thanks for any help
the_norris
Its the first Sticky post under 'ADSL and Broadband'.
Here a direct link to it:
http://portal.plus.net/central/forums/viewtopic.php?t=21604
Phil
Juniper or Redback
Thanks for that. Am connected to Redback so will try and hook up with a Juniper
the_norris
Hmm the BT 'Centrals' Lottery. Smiley
Hopefull this will be sorted soon - see the latest Announcement on this.
http://portal.plus.net/central/forums/viewtopic.php?t=22262
Right now, I have a small utility on Usertools that will tell you which gateway you are on.
It can be found at the following address: http://users.plus.net/@gateway
It is designed for a much larger suite of tools, so may be removed to a new location in the future.
Also let me know if it breaks, so I can fix it.
