changing to router
alkan
changing to router
at the moment i am using a binatone adsl 500 modem and am considering changing it to a netgear dg834 v3 router/modem. are there any problems i should be aware of in swapping these. or is it as easy as ive been told.
Plusnet Staff
Plusnet Staff
Fixes: 159
changing to router
Routers are generally pretty easy to set up, Netgears are some of the easiest. The connection settings you need can be found at the link below.
http://portal.plus.net/support/broadband/help_and_setup/connections_settings.shtml
 Chris Parr
 Plusnet Staff
alkan
changing to router
my m/board has a usb2/lan 1 (10/100) port which im assuming means i dont have to connect the router via usb but can use the lan facility via cable. am i correct in this.
changing to router
Yes, connecting via USB would remove part of the benefit of using a router.
I'd add my recomendation to the list for the Netgear range too. Wink
