changing to a modem
changing to a modem
just out of curiousity ,if i was to change from my solwise 110 router to a modem would there be much to do set up wise,or would it be virtually plug in and connect.also would a normal modem be suitable if i upgraded to a 1mb con.cheers
1 REPLY
changing to a modem
Setting up a modem would be easy - no problems there. It would also be able to cope with higher speed ADSL connections.
However, that said, if your question is anything more than hypothetical, then I must discourage you! A router is far better than any modem.
Thomas
