cant reach java.sun.com
anyone else have issues reaching http://java.sun.com ? I can only reach it using someone else as a proxy Sad
It is working fine for me. Can you post the output of a traceroute to that site?
Tim
Re: cant reach java.sun.com
I have similar type problems. I have checked my machine for viruses using norton, AVG and housecall. Haven't tried the java.sun.com. But I can't reach:
www.ebay.co.uk
www.ebay.com
www.tiscali.co.uk
www.tiscali.com
www.easyjet.com
www.mcafee.co.uk
www.mcafee.com
Also another machine on my network has the same problems!!! Don't think this has a virus neither. I use the Kerio firewall, but the problem still occurs with it turned off!
Tracert's below...
ICheesyocuments and SettingsNew UserDesktop>tracert www.mcafee.com
Tracing route to www.mcafee.com [216.49.88.12]
over a maximum of 30 hops:
1 21 ms 21 ms 21 ms 10.0.0.2
2 22 ms 21 ms 23 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
3 24 ms 23 ms 23 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
4 23 ms 23 ms 25 ms gigabitethernet2-1-110.ipcolo1.London1.Level3.ne
t [212.113.11.61]
5 25 ms 25 ms 23 ms ae0-54.mp2.London1.Level3.net [212.187.131.146]
6 90 ms 91 ms 89 ms so-1-0-0.bbr2.NewYork1.level3.net [212.187.128.1
53]
7 91 ms 89 ms 89 ms gigabitethernet5-1.core1.NewYork1.Level3.net [64
.159.17.101]
8 90 ms 91 ms 91 ms Broadwing-Level3-oc12.NewYork1.Level3.net [63.21
1.54.70]
9 94 ms 93 ms 93 ms P5-1.c0.wash.broadwing.net [216.140.8.193]
10 166 ms 165 ms 165 ms P2-0.c0.hywr.broadwing.net [216.140.16.1]
11 165 ms 165 ms 165 ms P2-0.a0.hywr.broadwing.net [216.140.2.2]
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * *
ICheesyocuments and SettingsNew UserDesktop>tracert www.easyjet.com
Tracing route to lb.wip.easyjet.com [213.212.64.42]
1 24 ms 21 ms 19 ms 10.0.0.2
2 22 ms 23 ms 21 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
3 25 ms 23 ms 23 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
4 23 ms 23 ms 23 ms lon1-10.nildram.net [213.208.106.89]
5 23 ms 23 ms 23 ms lon1-9.nildram.net [195.149.20.130]
6 24 ms 23 ms 23 ms 195.66.224.145
7 29 ms 27 ms 27 ms 62.73.128.29
8 28 ms 29 ms 29 ms 62.73.128.45
9 35 ms 35 ms 33 ms 62.73.128.42
10 35 ms 33 ms 33 ms 62.73.128.60
11 35 ms 35 ms 33 ms 62.73.128.62
12 33 ms 33 ms 33 ms 213.212.67.20
13 33 ms 33 ms 35 ms 213.212.67.18
ICheesyocuments and SettingsNew UserDesktop>tracert www.ebay.co.uk
Tracing route to www.ebay.co.uk [66.135.192.41]
2 23 ms 21 ms 22 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
3 24 ms 23 ms 24 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
4 25 ms 23 ms 25 ms gigabitethernet2-1-110.ipcolo1.London1.Level3.ne
t [212.113.11.61]
5 25 ms 23 ms 23 ms ae0-52.mp2.London1.Level3.net [212.187.131.34]
6 89 ms 89 ms 89 ms so-1-0-0.bbr2.NewYork1.level3.net [212.187.128.1
53]
7 166 ms 165 ms 165 ms so-0-0-0.mp1.SanJose1.level3.net [64.159.1.133]
8 166 ms 165 ms 165 ms so-2-0-0.gar1.SanJose1.level3.net [4.68.112.50]
9 168 ms 167 ms 167 ms so-11-0.hsa3.SanJose1.Level3.net [209.244.13.230
10 * * * Request timed out.
11 * * * Request timed out.
ICheesyocuments and SettingsNew UserDesktop>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ETHEREAL
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-30-18-60-36-48
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 10.0.0.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.2
DNS Servers . . . . . . . . . . . : 195.60.0.5
10.0.0.2
DNS Server was changed to bypass a DNS problem with plus.net
This could be the QHosts-1 trojan - see http://vil.nai.com/vil/content/v_100719.htm for more information.
Tim
Tim
Tim, thanks for the comment. I've already run Symantec's QHosts trojan detector with no detections; also looked around for the registry and host file sideeffects but with nothing found. I think the QHosts virus would stop the packets getting to the machines? But I'm definately getting out. I don't think it's anything to do with an explorer virus; I have downloaded Mozilla Firebird and I get the same symptoms; also downloaded WGET and get the same problem. I think PlusNet are hoping the problem goes away; but I'm stuck with no access to these sites. I will try a dial-up connection tonight to confirm that it is PlusNet but it's too slow to run with.
Can you post a tracert and tell us which DNS servers you are using?
Also, does http://192.18.97.71 work?
I have tracert's below, any others you wish to see?
I was originally using the one's assigned by my PlusNet ADSL connection. But I have (as the ipconfig shows below) changed to using PowerNet's 195.60.0.5 which I use at work.
Sorry, I was referring to kiaora'a original problem Smiley
Have you tried accessing the affected web sites using the IP address instead of the host name?
Tim
That's the one to try Wink
I was referring to leighfwarren's problem Wink.
Tim
So was he.
He posted a link to a IP address, rather than a host.
I'm quite, quite confused now. Http://java.sun.com is the same as http://192.18.97.7. It mainly refers to kiaora's problem, although anyone having DNS troubles could try the same thing.
So was he.
The Wink in my post should have given you a clue that I was being facetious!
Tim
I was suggesting that leighfwarren tried the same thing for the web sites he is having problems accessing. The name resolution is obviously working for tracert on his PC though.
Tim
