cant get any webpages
I connect with a plus net modem on broadband. It connects ok shows I connect at 5 meg. If I try and open a webpage it says dns error. I can ping an ip ok but not by name. My ipconfig shows I have the correct dns picked up from plus net. Some times I have to try connecting 5 times before it will connect it says bad username/passord but if I dont change it and keep dialing it lets me in ok.
I have tried setting the dns manualy to opendns but dns still dosnt work?
Help
1 REPLY
It sounds as if your tcip stack has gone wonky. Open a cmd window and type
netsh int ip reset reset.txt
reboot and it should be ok
