cant connect
cant connect
Access runner says connecting but never does, connection stopped about 11pm 15/10/02 and cant connect anymore,surley someone knows the prob
chino
RE: cant connect
In the Access runner control pannel does it state connection established ?
If it states trying to connect in the control pannel make sure that you have all your cables connected correctly with a splitter and all the other phones in the house have splitters or are unplugged. You are plugged into the main master socket...
Regards,
cUnDaLl
RE: cant connect
> Regards,
> cUnDaLl
> Was a BT fault
