cant browse
PhillipH
cant browse
heya
well i just got my adsl activated my bt and then by plus net.
i can connect but i cannot surf the internet.
do i have to change some internet explorer settings? (in browser options)?
RE: cant browse
> heya
Hi, Im having same problem as of last saturday all was well went out for a few hours came back,tried to log back on and now it wont load any web pages at all, it says i have an adsl connection and im connected but all i get is page cannot be found in ie6 and at bottom it says dns error ive phoned plusnet up they gave me new ip but still same problem PLEASE HELP IM DOING MY HEAD IN....
thank you
Jason Turner
RE: cant browse
PlusNet is always having problems.
DNS loss is part of it, you will have to get used to that.
But in the meantime you can change your DNS servers from PlusNet over to BT and your web pages will display.
PlusNet DNS Servers:
212.159.11.150
212.159.13.150
BT DNS Servers:
213.120.62.100
213.120.62.101
Don't know if it's really allowed, but i do it, as im tired of the PlusNet DNS splitting.
and paying £23.99 for it,
so i so no harm in changing to BT DNS.
afteral you are paying and you get no compensation on here when the service fails.
See my post from last week if you don't know how to change the servers.
or post back here, and i'll retype it all out.
good luck!
Jason
RE: cant browse
PS>
I really should have asked you first,
did you set PlusNet's DNS server IP's on your IE internet options?.
If not, then do that now.
click internet option, find PlusNet dial connection for your ADSL modem, onece you find it, right click on it, highlight properties, find the Networking tab.
Once there you can see many options, click the properties button (not tab) and this should bring up a box to let you enter your PlusNet IP address, enter it, by selecting static IP number.
Then below that, you will see DNS servers.
check the box, then enter PlusNet DNS servers.
212.159.11.150
212.159.13.150
Then click apply. and disconnect,
you have to disconnect each time you make a chnge to your connection.
The reconnect, try thr webpages again.
if it still fails.. then enter the BT DNS numbers until PlusNet sort it out.
BT DNS Servers:
213.120.62.100
213.120.62.101
And again remember to disconnect after you make changes then reconnect again to make them change.
I find the BT DNS works great.. sometimes better than PlusNet Shocked)
Don't ask me why.. it just does Tongue
Good luck people.
Jason
RE: cant browse
Forget to say..
if you can't find your PlusNet static Ip number,
then connect to my web server.
http://212.159.68.178 or http://dolan.plus.com
the first page will tell you what your IP number is Smiley
I use server side includes on .shtml for index page.
Regards,
Jason
