can u connect to this site?!
http://www.civictype-r.co.uk/phpbb2/index.php
All i'm getting is a blank page where as my mate on Freeserve broadband can get the page up fine. Cry
Any ideas?
Hi
No I get same blank page :?:
Not working for me, in Opera7.52 it gives a load of garbled ascii, in IE6 a blank page
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
I thought it might be Plusnet but my brother can get on it fine and he's on Plusnet. Very odd!!! :?
Anyone at Plusnet any ideas?
The forum has had a problem or two over the last few months. This is down to a glitch at the host.
It was mentioned somewhere on the forum the last time I logged in (Saturday)
Civic TypeR # 13471
Cheers for the info m8, i aint been on the forum in a while and had only had a brief look from work today which was fine.
Other people can connect at the same time as i cant connect.
Is this along the same lines as the problem?
Last time it came up page not found. I gather it is something to do with the DNS from the host.
Outage was only a few days last time.
Try changing your DNS servers to one of the alternates and see if it makes a difference. I havn't time at the mo to try.
Something is wrong with the site.
If you look at the source code for the blank page it has a header but the body part is a blank. Just body< >,/body
The non forum parts of the site work.
Yes i can get on these fine. Will give the different DNS servers a try...
I can access the forum on the works (non Plusnet) connection.
The current problem is not the same host problem as happened in Nov 2003 and Feb 2004.
works ok 4 me 2
Hmm didnt work with different DNS servers manually put in but it works from where i work (not Plusnet).
How come some Plusnet users can get on and some cant?! very odd. :? Cry
glyndev
I can access via http://proxy.guardster.com/ but not via +net.
I wonder if the host is blocking an +net ip range.
That could well be the case.....if so i wonder why? :?
