can not find server
wattsy
can not find server
It is usually Plusnet site, have to reboot several times
DNS servers 212. 159. 13. 49
212. 159 13 50
Thanks for your response, grateful for any further advice.
Regards
wattsy
Can not find Server
Sad I keep getting the massage can't find server, sometimes can solve it if I reboot. But this doesn't always work and it appears to be getting worse. Shocked Any advice would be appreciated.
Regards Smiley
Can not find Server
It could possibly be a DNS issue. To check which DNS servers you're currently using:
[list=1]
  • Click "Start"
  • Click "Run"
  • Type "cmd" in the box
  • In the black window which appears, type "ipconfig /all"[/listShocked]There should be a section which says "DNS Servers" - can you let us know what those are.
    Also, does this happen on specific sites, if so which. Or is it just at random?
