can i get 2mb
can i get 2mb
Hi
i have a vigor 2600 router and it displays this
SNR Margin 35.5
Loop Att. 29.5
will i be able to get 2mb
Regards
Nick
1 REPLY
Alecto
can i get 2mb
If those figures relate to Downstream, then yes you are under the 2Mb limit for attenuation of 43dB.
If they relate to upstream, you will need to get the downstream figures as they are the ones that matter.
